No active polling method detected
Hi Guys,
I did all the possible search and couldn’t find the solution, the issue disapears after I do the command " ./poller-wrapper.py 16" but comes back again after some minutes. seems the scheduler for polling is not working but I don’t know how to fix it :slight_smile:
bash-4.4$ ./validate.php
LibreNMS 24.6.0-51-g991424e54 (2024-07-09T23:02:40+02:00)
DB Schema 2024_04_29_183605_custom_maps_drop_background_suffix_and_background_version (294)
PHP 8.1.29
Python 3.6.8
Database MariaDB 10.3.39-MariaDB
RRDTool 1.7.0
SNMP 5.8
[OK] Composer Version: 2.7.7
[FAIL] No active polling method detected
Modified Files:
.codeclimate.yml
.editorconfig
.env.example
.env.travis
.git-blame-ignore-revs
.github/FUNDING.yml
.github/ISSUE_TEMPLATE/bug_report.yml
.github/ISSUE_TEMPLATE/config.yml
.github/ISSUE_TEMPLATE/device_bug.yml
.github/PULL_REQUEST_TEMPLATE.md
.github/ci-reporter.yml
.github/label-actions.yml
.github/lock.yml
.github/no-response.yml
I see the following error on the cron job :slight_smile:
crond.service - Command Scheduler
Loaded: loaded (/usr/lib/systemd/system/crond.service; enabled; vendor preset: enabled)
Active: active (running) since Wed 2024-07-10 15:39:29 CEST; 2h 18min ago
Main PID: 1012 (crond)
Tasks: 1 (limit: 49015)
Memory: 162.9M
CGroup: /system.slice/crond.service
└─1012 /usr/sbin/crond -n
crond[1012]: (system) RELOAD (/etc/cron.d/librenms)
rond[1012]: (/opt/librenms/cronic) ERROR (getpwnam() failed - user unknown)
Out of curiosity is your polling working regardless? I too get the same error but it constantly comes and goes but I have no polling issues, all graphs are fine. My poll time is currently at 79 seconds and i have this idea that if its more than 30 seconds it spits out this error.
The below pic will flick between OK and Fail for wrapper pollers and active polling method
Does the librenms user exist on your system? It looks like crond is saying it is trying to run the poller wrapper with a user account that doesn’t exist on the system.
yeah my issue is that the polling doesnt happen unless I trigger it manually on the CLI
yes it is exists, i fixed that but still the same issue unfortunately
issue solved, i had a parallel installaton running and had to edit another config.php for maria db access. thank you
