I’m configuring AD authentication, and roles seem to be applying correctly through auth_test.php but not making it to the web UI. In this output I have global-read from $config[‘auth_ad_global_read’] = 1 in my config.php, and admin from group membership.
AD bind success
Password:
Authenticate user ...:
AUTH SUCCESS
User (...):
user_id => ...
username => ...
realname => ...
email => ...
descr =>
can_modify_passwd => 0
Groups: CN=LibreNMS Admin,OU=...
Roles: global-read; admin
I was looking through prior posts, and I’m not sure whether there was a transition from “level” to “role” for the AD config. The docs say to use lnms config:set auth_ad_groups.ad-admingroup.level 10. When I try to set that, I’m told that auth_ad_groups.ad-admingroup.roles is required. I set the role through the web UI, but permissions aren’t carrying over before or after setting level 10 manually.
$ lnms config:get auth_ad_groups
"LibreNMS Admin": {
"roles": [
"admin"
"level": 10
Anyone have an idea of what I’m doing wrong?
