Hello all,
if I add a Device is it not shown in the device list. If I try to add the same device again librenms says that this device is already in use and I can remove it. I see the devices in the widget but it seems that the devices will not discovered. It is always generic device but at adding the device the snmp check works.
It seems everything is ok.
It is a fresh install on Debian 10
./validate.php
Component | Version |
LibreNMS | 21.3.0-24-gc10c63070 |
DB Schema | 2021_03_26_014054_change_cache_to_mediumtext (202) |
PHP | 7.3.27-1~deb10u1 |
Python | 3.7.3 |
MySQL | 10.3.27-MariaDB-0+deb10u1 |
RRDTool | 1.7.1 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 2.0.11
Any Idea ? In which logfiles should I search?
