[FAIL] Discovery has not completed in the last 24 hours, check the cron job
[WARN] Some devices have not been polled in the last 5 minutes.
You may have performance issues. Check your poll log and see: http://docs.librenms.org/Support/Performance/
INFO: worker Thread-10 finished device 38 in 1 seconds
INFO: worker Thread-4 finished device 273 in 1 seconds
INFO: worker Thread-2 finished device 266 in 1 seconds
INFO: worker Thread-16 finished device 145 in 1 seconds
INFO: worker Thread-8 finished device 183 in 1 seconds
INFO: worker Thread-9 finished device 143 in 1 seconds
INFO: worker Thread-3 finished device 182 in 1 seconds
INFO: worker Thread-12 finished device 37 in 2 seconds
INFO: worker Thread-6 finished device 11 in 12 seconds
INFO: poller-wrapper polled 294 devices in 397 seconds with 16 workers
WARNING: the process took more than 5 minutes to finish, you need faster hardware or more threads
INFO: in sequential style polling the elapsed time would have been: 6075 seconds
WARNING: Consider setting a minimum of 22 threads. (This does not constitute professional advice!)
In rrd command i see some error: RRDTool Output
1377x339
ERROR: Unable to connect to rrdcached: Permission denied
