I’m trying to enable the Settings tab in the WebUI for pollers. I cannot find this option in the config.php or poller.php. All other features work great and no issues validating. Any ideas?
What I’m trying to accomplish:
The option you are looking for is available only when you use dispatcher service as polling method
From the screenshot, i see that you are using standard poller method
This was the answer. Once I set up dispatcher service correctly, the settings tab appeared.
