we have added node in librenms. But this node shows “Never polled” and graphs are not showing correctly. can you help me to solve this issue. i attached screenshots for your reference, please check
Thank you!
Please run
./validate.php
| LibreNMS | 1.63-41-g2533064 |
| DB Schema | 2020_04_13_150500_add_last_error_fields_to_bgp_peers (164) |
| PHP | 7.2.10 |
| Python | |
| MySQL | 5.5.60-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.10.6
[FAIL] python3 not found
[WARN] Your local git contains modified files, this could prevent automatic upd ates.
Modified Files:
html/js/app.js
html/js/vendor.js
sudo setfacl -d -m g::rwx /opt/librenms/rrd /opt/librenms/logs /opt/libr enms/bootstrap/cache/ /opt/librenms/storage/
sudo chmod -R ug=rwX /opt/librenms/rrd /opt/librenms/logs /opt/librenms/ bootstrap/cache/ /opt/librenms/storage/
Files:
/opt/librenms/bootstrap/cache/services.php
