Nokia SAP doesn't graph and hided from device
Hi!
Thanks to @loopodoopo for https://github.com/librenms/librenms/pull/12432/files
I’m dealing with Hardware 7250 IXR-e, Operating System Nokia SR OS (TiMOS) 20.10.R2
I have re-discovered the device but in Device > Routing > MPLS I can’t see anything.
I can go to Routing > MPLS > SAP and I can see all SAP lines. However I can enter on any but there’s no graph, all values are 0
Can anyone give me a track?
Hi @gil.obradors,
7750 and 7250 have different OID’s for SAP traffic, I have only implemented 7750 because this is the bigger part of our network. I believe the following OID’s should be used for 7250:
Sap Ingress Forwarded In-Profile Bytes
.1.3.6.1.4.1.6527.3.1.2.4.3.6.1.12
Sap Egress Forwarded In-Profile Bytes
.1.3.6.1.4.1.6527.3.1.2.4.3.6.1.20
I’m not 100% sure if there are also counters for SAP drops as I have implemented them for 7750. Would you care to create a PR?
ack!
I’m from python and c/c++ , but I’m going to try to create PR!
Many thanks!
Oh, the topic it’s more easy to explain, more difficult to resolve.
I need sapBaseStatsIngressPchipOfferedHiPrioOctets and sapBaseStatsEgressQchipForwardedInProfOctets instead of configured in PR… This will be more complciated to manage, because every customer will have deployed differrents configurations.
Is safe and consistent to add more fields into the graph that you configured? I 'm worried about the data and time that GetBulk will consume. I don’t know the architecture of Librenms for the polling process
Do you think we can introduce this fields in your graph? Is safe?
( I have hundred of SAP lines and I will have more) My other plan is out of librenms with gRPC, but could be fine have this data into Librenms…
What do you think ?
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.3           sapBaseStatsIngressPchipOfferedHiPrioPackets         LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.4           sapBaseStatsIngressPchipOfferedHiPrioOctets          LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.19          sapBaseStatsEgressQchipForwardedInProfPackets        LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.20          sapBaseStatsEgressQchipForwardedInProfOctets         LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6               sapBaseStatsTable                                    NODE
1.3.6.1.4.1.6527.3.1.2.4.3.6.1             sapBaseStatsEntry                                    NODE
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.1           sapBaseStatsIngressPchipDroppedPackets               LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.2           sapBaseStatsIngressPchipDroppedOctets                LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.5           sapBaseStatsIngressPchipOfferedLoPrioPackets         LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.6           sapBaseStatsIngressPchipOfferedLoPrioOctets          LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.7           sapBaseStatsIngressQchipDroppedHiPrioPackets         LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.8           sapBaseStatsIngressQchipDroppedHiPrioOctets          LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.9           sapBaseStatsIngressQchipDroppedLoPrioPackets         LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.10          sapBaseStatsIngressQchipDroppedLoPrioOctets          LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.11          sapBaseStatsIngressQchipForwardedInProfPackets       LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.12          sapBaseStatsIngressQchipForwardedInProfOctets        LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.13          sapBaseStatsIngressQchipForwardedOutProfPackets      LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.14          sapBaseStatsIngressQchipForwardedOutProfOctets       LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.15          sapBaseStatsEgressQchipDroppedInProfPackets          LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.16          sapBaseStatsEgressQchipDroppedInProfOctets           LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.17          sapBaseStatsEgressQchipDroppedOutProfPackets         LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.18          sapBaseStatsEgressQchipDroppedOutProfOctets          LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.21          sapBaseStatsEgressQchipForwardedOutProfPackets       LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.22          sapBaseStatsEgressQchipForwardedOutProfOctets        LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.23          sapBaseStatsCustId                                   LEAF  TmnxCustId
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.24          sapBaseStatsIngressPchipOfferedUncoloredPackets      LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.25          sapBaseStatsIngressPchipOfferedUncoloredOctets       LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.26          sapBaseStatsAuthenticationPktsDiscarded              LEAF  Counter32
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.27          sapBaseStatsAuthenticationPktsSuccess                LEAF  Counter32
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.28          sapBaseStatsLastClearedTime                          LEAF  TimeStamp
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.29          sapBaseStatsIngressCPMPackets                        LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.30          sapBaseStatsIngressCPMPacketsHi                      LEAF  Counter32
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.31          sapBaseStatsIngressCPMPacketsLo                      LEAF  Counter32
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.32          sapBaseStatsIngressCPMOctets                         LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.33          sapBaseStatsIngressCPMOctetsHi                       LEAF  Counter32
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.34          sapBaseStatsIngressCPMOctetsLo                       LEAF  Counter32
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.35          sapBaseStatsIngPchipRcvdValidPkt                     LEAF  Counter64
1.3.6.1.4.1.6527.3.1.2.4.3.6.1.36          sapBaseStatsIngPchipRcvdValidOct                     LEAF  Counter64
rrdtool does not really allow modifications of the structure. The best way to add them is to create a new rrd file. One graph can reference multiple files. Other than organization, there is no downside to multiple files.
Thanks @murrant for the hint!
