Can I get a list of the frequencies used by our radios? I see I can select Wireless and then Frequency. I would like to be able to report on our backhauls and aps only and export it.
Im not sure what you mean.
If you go, as you said, to Wireless -> Frequency
does your backhauls and APs doesnt report the frequency?
Yep, I can see the frequency of every radio in the system. I would like to see only AP and backhaul radios and be able to export to a spreadsheet or flat file.
I think you cant filter that and, for sure, there is no export button.
Contributions are welcome!
