Welcome to the Oxidized help section.
not able to see the config but sync is happening.
You are free to ask any questions surrounding Oxidized, it does not need to be specific to LibreNMS integration.
Is this issue with all deices ?
are you able to login to device manually from oxidized node ?
are you able to see config directly from oxidized WEBUI ?
