Is there anyone who wrote a transport for the NTFY product in Librenms transport?
Or is there anyone who integrates with the NTFY product?
Best Regards
Best Regards
You could use the default API Transport for NTFY. This is our config:
API Method: POST
API URL: https://ntfy.sh/your-topic-here
Options:
headers: Content-Type: text/plain
body: {{ $title }} {{ $msg }}
Auth Username:
Auth Password:
I am self hosted. I had to enable SMTP on my NTFY server for some other devices. I just send email to the NTFY server from LibreNMS. It works OK.
I’ve been using API transport for ntfy, but there’s a case where a dedicated transport might be useful.
If you set Priority=urgent for a down event ntfy can trigger a persistent alert in the app that alarms continuously until acknowledged. I can manually set this in the API transport headers, but it means that recovery alerts are also tagged as urgent when I’d rather that they weren’t (when asleep, I want to be woken by a system down event, but not by a recovery event).
From the ntfy docs:
| Priority | ID | Name | Description |
| Max priority | 5 | max/urgent | Really long vibration bursts, default notification sound with a pop-over notification. |
| High priority | 4 | high | Long vibration burst, default notification sound with a pop-over notification. |
| Default priority | 3 | default | Short default vibration and sound. Default notification behavior. |
| Low priority | 2 | low | No vibration or sound. Notification will not visibly show up until notification drawer is pulled down. |
| Min priority | 1 | min | No vibration or sound. The notification will be under the fold in Other notifications. |
If anyone has a workaround for setting ntfy status to correspond roughly with LibreNMS severity, I’d be grateful.
