I have a single poller running with RRDCached enabled on the host. Is there a limit to the number of workers per poller? (see attached picture)
As I am adding devices, the consumed worker seconds keeps exceeding the maximum worker seconds.
8f2d1881c914:/opt/librenms$ ./validate.php
| LibreNMS | 21.12.0 |
| DB Schema | 2021_25_01_0129_isis_adjacencies_nullable (229) |
| PHP | 7.4.26 |
| Python | 3.9.5 |
| MySQL | 10.5.13-MariaDB-1:10.5.13+maria~focal |
| RRDTool | 1.7.2 |
| SNMP | 5.9 |
[WARN] You have the old alerting system enabled - this is to be deprecated on the 1st of June 2015: Redirecting to Google Groups
