Observium Migration
Hello.-
I want to migrate from observium to LibreNMS.
How to export the data from the observium database to the LibreNMS DB?
Observium has a problem that creates blank spaces in graphics. Does the same thing happen with LIbreNMS?
Observium is currently mounted on a VM with 4 Cores and 8 Gb of RAM on an HP Proliant DL360 G9.
Best Regards.
Did you check this? https://docs.librenms.org/#Installation/Migrating-from-Observium/
I will check. Thanks
What about White spaces on rrd grapghs?
You can’t export the database from obse…, it’s not compatible anymore.
Whitespace means you’ve got issues polling data in time, it may or may not happen with LibreNMS, you’ll just have to try.
I have more 1000 devices on observium, I have to add again on LibreNMS? Is not other way?
How can I solve the pooling data problem?
Yes you will need to add them, it’s easy enough to script that though against ./addhost.php or the api.
