Offline Map
I work in an environment where there is simply no real internet connection.In order to make the world map work offline, i have to make a local tile server. I followed many guides all the way through but still do not fully understand all of the components to a full offline map server.I am a bit newb to this and i may ask some stupid questions.Should i configure the tile server on a different device to make it work with librenms?Is there another easy way to make the worldmap reachable offline?
Any help or links to explain this to me would be amazing.
Hi!
I think you would be better off asking this question in an OpenStreetMap forum.
I have done loads of OSM map editing, but never set up my own tile server.
If you read the requirements here, it sounds like you need quite a good server, so personally I would recommend running it on a separate server. If nothing else, if it runs out of disk space or crashes, it won’t bring down your monitoring system. In my opinion, monitoring is critical, a nice map is not :wink:
The latest compressed planet.osm file is 83GB!
I need to display my country map which is less than 83GB.I agree with you,monitoring is more important.I just liked this awesome eye candy feature!
