Run poller.php and you will get this outpup. In gui many important fields are missing like physical disk.
The output of ./validate.php
Component
Version
LibreNMS
1.69-39-g820cf1d
DB Schema
2020_11_02_164331_add_powerstate_enum_to_vminfo (190)
PHP
7.3.24
Python
3.6.8
MySQL
5.5.65-MariaDB
RRDTool
1.4.8
SNMP
NET-SNMP 5.7.2
OpenSSL
[OK] Composer Version: 2.0.7
Discovery:
https://paste.c-net.org/MerchantWaffles
Poller:
https://paste.c-net.org/RobbinsDresser
So as you can see in the poller file after the RAM state check every state is blank. I am running proxmox with OMSA installed. Anyone know what this is. i cal see there are lots of errors in poller.php but why?
Hardware is Poweredge R620 and OMSA is 9.3.0
No one know why this happend? or have i not provided enough information?
What could be the problem, if you se in the poller there are lots of php errors.
Is there no one here using a dell server?
Looks like when i do snmp walk on the server its missing. How do i fix this.
Do i need to activate them here:
Still have not managed to fins a solution to this problem.
I know your thread has been around for a while now. I’ve found that on Ubuntu I needed to modify the snmpd service file (/lib/systemd/snmpd.service) to remove this bit “-I -smux,mteTrigger,mteTriggerConf”, that said I’m still working on the other piece which I think may require a code update. My thread is here:
After looking at the patch file from the referenced forum post, I was able to determine that if I add
“mib_dir: dell” to my linux.yaml file everything pulls in as it should. I’m not sure if this is something that needs to be added to the source or if doing so is incorrect.
Thank you very much. I have spent so much time trying to figure this one out. Now everything work as expected
Good to hear, I know there was some changes made to the code. I’m glad that you’re taken care of now as well.
system
Closed
24 September 2021 11:05
12
