validate.php output
[email protected]:/opt/librenms# ./validate.php
Component | Version |
LibreNMS | 1.63-26-g9b22bcc5b |
DB Schema | 2020_04_19_010532_eventlog_sensor_reference_cleanup (164) |
PHP | 7.2.24-0ubuntu0.18.04.4 |
MySQL | 10.1.44-MariaDB-0ubuntu0.18.04.1 |
RRDTool | 1.7.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.10.5
[WARN] Your install is over 24 hours out of date, last update: Sun, 03 May 2020 11:22:48 +0000
Modified Files:
bootstrap/cache/.gitignore
logs/.gitignore
rrd/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
Error from the log files
If I use the auth test then I get the following
logs/librenms.log.1:[2020-05-04 20:47:36] production.ERROR: Auth Error (ldap): No user (165555) [kkot]
When I try to add a group to the webUI for openldap it throws settings.validate.ldap-groups
Something has to be working in order for it to pull my uid and number but afterwards it always fails. I cannot get any groups to work for authentication no matter how I configure the group type or membership attribute.
