hi
I can finally retrieve metric and hostname and send them to opentsdb as you see in the picturesrc
but I have one last problem I can not recover the values
And I did not understand how you made made it to retrieve it for influxdb and graphite
this is the code
global $opentsdb;
$config['opentsdb']['host'] = 'opentsdb-qlf-write.fr';
$config['opentsdb']['port'] = 4242;
$hostname_tag = sprintf('%s=%s ', 'hostname', $device['hostname']);
$metric=$measurement;
$tmp_tags = array($hostname_tag);;
$timestamp=Time();
$hostname="$hostname_tag";
$opentsdb = fsockopen($config['opentsdb']['host'], $config['opentsdb']['port']);
foreach ($tags as $k => $v) {
$v = preg_replace(array('/ /','/,/','/=/'), '_', $v);
if (!empty($v)) {
array_push($tmp_tags, sprintf('%s=%s ', $k, $v));
foreach ($fields as $k => $v) {
$line = sprintf('put %s %d %d %s', $metric, $timestamp, $v, $hostname);
d_echo("Sending to OPenTSDB: $line\n");
fwrite($opentsdb, $line . "\n");
In fact I must through an array php the 3 table device fields and tags
thank youPreformatted text
