It’s come to my attention that the ‘Operating System’ field for devices is never updated, except for with one device. For example, one device used ‘Linux 4.19.0-16-amd64 (Debian GNU/Linux 10)’ on its first discovery, but has been on ‘Linux 5.10.0-15-amd64 (Debian GNU/Linux 11)’ for 2 months.
This field did update for one device that was upgraded about 20 minutes ago after I ran the poller
manually (although it might have updated by itself; I don’t know if the poller ran before I ran it manually after upgrading the device). This is the only exception. I’m not sure what’s different about this device.
Looking in the code, I see that the polling for the os module is done in the poll function in LibreNMS/Modules/Os.php. Code: https://github.com/librenms/librenms/blob/22.8.0/LibreNMS/Modules/Os.php#L53
The if ($os instanceof OSPolling) branch is false. LibreNMS checks if files exist in includes/polling/os/, but the only file in there is vmware-esxi.inc.php, so I assume that’s somewhat deprecated. Those branches are also false. Finally, we end up in the branch that outputs echo "Generic :(\n"; and the value of the fields that should be updated is set as follows:
$deviceModel->version = ($version ?? $deviceModel->version) ?: null;
$deviceModel->hardware = ($hardware ?? $deviceModel->hardware) ?: null;
$deviceModel->features = ($features ?? $deviceModel->features) ?: null;
$deviceModel->serial = ($serial ?? $deviceModel->serial) ?: null;
None of these variables are set in Os.php or in vmware-esxi.inc.php, so I assume we’re looking for globals. Printing these:
printf('version is %s', $deviceModel->version);
printf('version is %s', $version);
… yields:
version is 4.19.0-18-amd64
version is
So, the null coalescing operator ($version ?? $deviceModel->version) returns the second operand $deviceModel->version (4.19.0-18-amd64). The ternary operator evaluates to the left operator, so $deviceModel->version is $deviceModel->version, i.e. it’s unchanged.
The poller module outputs:
#### Load poller module os ####
Generic :(
SQL[select * from `locations` where `locations`.`id` = ? limit 1 [2] 0.19ms]
Hardware: QEMU Standard PC (i440FX + PIIX, 1996)
OS Version: 4.19.0-18-amd64
OS Features: Debian GNU/Linux 10
Serial: Not Specified
>> Runtime for poller module 'os': 0.0018 seconds with 181024 bytes
>> SNMP: [0/0.00s] MySQL: [1/0.00s]
It also seems counter-intuitive odd that OS version is set to 4.19.0-18-amd64 (that’s the kernel) and OS features is set to Debian GNU/Linux 10 (that’s the OS version). Is this intended behaviour?
Any hints?
validate.php output:
LibreNMS | 22.8.0-133-g0f14a7c17
DB Schema | 2022_07_19_081224_plugins_unique_index (244)
PHP | 7.4.30
Python | 3.7.3
Database | MariaDB 10.6.9-MariaDB-1:10.6.9+maria~deb10-log
RRDTool | 1.7.1
SNMP | 5.7.3
[OK] Composer Version: 2.4.1
[OK]
[OK] MySQl and PHP time match
[WARN] Your install is over 24 hours out of date, last update: Tue, 23 Aug 2022 22:24:35 +0000
Modified Files:
rrd/.gitignore
