Hello Community,
how can I monitor a Oracle database if its running and how many tablespace are free?
Hello Community,
I have never seen Oracle monitoring. But this what we have https://docs.librenms.org/#Extensions/Applications/ or https://docs.librenms.org/#Extensions/Services/ if not then someone will have to contribute code/support for this.
which parameter must I insert in the field?
Depends on the plugin. They’re all a bit different. Your best bet is probably to go to the plugin location on your LibreNMS server (usually /usr/lib/nagios/plugins
), have a look at ./check_oracle --help
, see what the options are and play with it on the CLI until you get the output you need. Then use those in Parameters.
