arista EOS device
in the event log “Error polling ospfv3 module. Check log file for more details.”
Here is the log file
| LibreNMS | 25.2.0-18-g4cfd5a886 (2025-02-28T04:09:23-05:00) |
| DB Schema | 2025_01_20_125000_create_ospfv3_ports_table (319) |
| PHP | 8.2.27 |
| Python | 3.10.12 |
| Database | MariaDB 10.6.18-MariaDB-0ubuntu0.22.04.1 |
| RRDTool | 1.7.2 |
| SNMP | 5.9.1 |
[OK] Composer Version: 2.8.6
[OK] Redis is functional
Modified Files:
resources/views/layouts/menu.blade.php
[FAIL] We have found some files that are owned by a different user than ‘librenms’, this will stop you updating automatically and / or rrd files being updated causing graphs to fail.
Files:
/opt/librenms/rrd/smokeping/__sortercache/data.lnmsFPing-1.storable
/opt/librenms/rrd/smokeping/__sortercache/data.lnmsFPing-0.storable
/opt/librenms/rrd/smokeping/network/10_248_147_50.rrd
/opt/librenms/rrd/smokeping/network/10_248_115_21.rrd
/opt/librenms/rrd/smokeping/network/10_248_147_40.rrd
/opt/librenms/rrd/smokeping/network/10_248_147_45.rrd
/opt/librenms/rrd/smokeping/network/10_248_147_60.rrd
/opt/librenms/rrd/smokeping/network/10_248_147_26.rrd
/opt/librenms/rrd/smokeping/network/10_248_147_55.rrd
/opt/librenms/rrd/smokeping/network/10_248_98_76.rrd
/opt/librenms/rrd/smokeping/network/10_248_115_23.rrd
/opt/librenms/rrd/smokeping/network/162_255_95_41.rrd
/opt/librenms/rrd/smokeping/network/10_248_115_22.rrd
/opt/librenms/rrd/smokeping/network/10_248_147_61.rrd
