Overlib Mouse Over Issue: Font sizes aren't consistent
While I was doing a bit of testing of a new LibreNMS installation, I noticed when I mouse over the mini graphs the mouse over graphs don’t have consistent font sizes.
The LibreNMS demo is having the same issue. If you look at the device (even though it’s down) you can see when you hover over the mini graph for Memory Pools and Voltage, the title font size in the upper left is not the same size. The hover over Voltage font size is much larger than the Memory Pool.
Here is a link to the device: https://demo.librenms.org/device/device=193/
I tested it with Chrome and Edge, also I’m using LibreNMS version 1.33-89-g0c49e9b
Not sure to understand, can you post a screen shot?
Here you can see the difference in the font sizes when I hover over the Main Memory and Voltage 0, please see the attached image.
Thanks,
Rob
You’re right, same issue here. Never noticed this before :grinning:.
It’s a bug and should be posted on GitHub with all mandatory information please:
