since a few weeks, after a update, i have the problem that i am missing “Overwrite IP” in the “Add Device” screen.
My version: [1.63-2-g055abcf44]
Me again.
Referring to https://github.com/librenms/librenms/issues/11565 i would like to ask if somebody knows the last version where “Overwrite IP” was in “Add Device”. I need this feature at all just in adding a device because i’m manually adding devices and do checks over the Internet. Much better would it be for me to readd this feature in the actual version with enabling it with a switch in the gui settings.
Found a solution adding new devices with the API.
can u please share how i manage to add a device with the “overwrite ip” as well ?? , i need this else i can access the sw config
thanks
