cealt
5 March 2021 01:20
1
on https://docs.librenms.org/Extensions/Oxidized/ at the section: Feeding Oxidized
You will need to configure default credentials for your devices in the Oxidized config,
LibreNMS doesn't provide login credentials at this time.
This is kind of alarming (no pun intended). Does this mean I can’t use my usual ssh keypair(s) for auth to my devices?
Hi @cealt ,
LibreNMS is basically saying, that’s oxidized configuration so you should be looking at the oxidized documentation for that bit.
# Configuration
## Debugging
In case a model plugin doesn't work correctly (ios, procurve, etc.), you can enable live debugging of SSH/Telnet sessions. Just add a `debug` option containing the value true to the `input` section. The log files will be created depending on the parent directory of the logfile option.
The following example will log an active ssh/telnet session `/home/oxidized/.config/oxidized/log/<IP-Address>-<PROTOCOL>`. The file will be truncated on each consecutive ssh/telnet session, so you need to put a `tailf` or `tail -f` on that file!
```yaml
log: /home/oxidized/.config/oxidized/log
input:
default: ssh, telnet
debug: true
ssh:
secure: false
http:
ssl_verify: true
This file has been truncated. show original
Cheers,
cealt
5 March 2021 19:41
3
Thanks. It’s often difficult (for me at least) to tell when the ‘librenms’ stuff stops and the ‘tool’ (oxidized) starts. This helps me get some context.
thank you again.
system
Closed
7 September 2021 19:41
4
