Oxidized Failed to Connect
I am trying to setup a Librenms and Oxidized build in our lab environment. Currently I was able to get Librenms installed and have it polling one device. I then installed Oxidized but can not get it up and running. When going to the “config” tab in librenms from the device it gives an error of " Whoops, looks like something went wrong. Check your librenms.log." When I check the same log file it just shows " cURL error 7: Failed to connect to SERVER port 8888: Connection refused " I am also unable to load the webpage via GUI for oxidized either.
What does systemctl status oxidized tell you?
● oxidized.service - Oxidized - Network Device Configuration Backup Tool
Loaded: loaded (/lib/systemd/system/oxidized.service; disabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Tue 2023-09-05 11:57:45 UTC; 1min 14s ago
Process: 526449 ExecStart=/usr/local/bin/oxidized (code=exited, status=1/FAILURE)
Main PID: 526449 (code=exited, status=1/FAILURE)
