I am having issues with pulling logs from Netgear devices. According to logs the ssh.rb module is expecting some regexp on the output, however it just times out. I tried to increase the timeout, however without luck.
as per the logs, when you login manually - you are entering enable password also
but in the oxidized config, you did not config enable pwd for netgear group
Hello, i have tried your way, however behaviour is exact the same. I also changed the source from LibreNMS API to router.db file in which i provided enable and its password as separate octet (example. netgear:10.59.0.24:MyPassword:EnablePassword etc.), but it does not work either.
Okay guys, i just checked the configs/ directory and i have found out that i was able to pull the configuration from one netgear device properly, it was one week ago. So it means i had working configuration and now i “only” need to find out what is messed out with the current configuration:
