Greetings All,
To preface I am by no means an expert in Linux, I know enough to get around and get myself in trouble. That being said…
I had a LibreNMS solution with oxidized. Everything was working fine, but decided that running with HTTP was no longer acceptable. I set up a self-signed certificate and was able to get the LibreNMS site working just fine, until a few days later I realized that I didn’t check any device configurations. I am greeted with the “We couldn’t retrieve the device information from Oxidized”.
I checked my Oxidized Source Settings:
source:
default: http
debug: false
http:
scheme: https
secure: false
url: https:///api/v0/oxidized
map:
model: os
group: group
headers:
X-Auth-Token:
(Note The indents are also correct, but not displaying properly on message)
If I curl my URL with the token, I get a listing of all hostnames, etc.
However when I try to query a configuration in Librenms, or get a list of sources in the Overview>Tools>Oxidized menu I get nothing or the error mentioned above.
In addition I see the following error on my CLI running oxidized: “HTTP parse error, malformed request (): #<Puma::HttpParserError: Invalid HTTP format, parsing fails.>”
My ssl cert has the URL the FQDN I am trying to connect to. The API works when using Thunder Client from a different machine, and my Librenms machine (same device as my oxidized device) can curl and see results.
Any thoughts or assistance would be happily accepted.
Thank You and Be Well
