I installed a new oxidized instance on a server separate from my librenms server. The librenms server is not able to retrieve the config. It also seems like oxidized is not getting the config because this is what I see when I do the below curl from the oxidized server…
curl http://127.0.0.1:8843/node/show/ogms-idf1-stack2?format=json
{“name”:“ogms-idf1-stack2”,“full_name”:“default/ogms-idf1-stack2”,“ip”:“10.240.2.12”,“group”:“default”,“model”:“IOS”,“last”:null,“vars”:null,“mtime”:“unknown”}
I have been able to:
from the oxidized server get a listing of devices view curl using the token and see device info from librenms
curl -H ‘X-Auth-Token: 01234567890’ https://librenms/api/v0/oxidized -k
This is my oxidized config below. Just using default groups
/root/.config/oxidized/config
username: switchuser
password: switchpassword
model: ios
interval: 3600
use_syslog: false
threads: 30
timeout: 20
retries: 3
rest: 0.0.0.0:8843
next_adds_job: false
vars: {}
models: {}
pid: “/root/.config/oxidized/pid”
input:
default: ssh, telnet
ssh:
secure: false
output:
default: git
git:
user: oxidized
email: [email protected]
repo: /home/oxidized/.config/oxidized/devices.git
source:
default: http
http:
url: https://librenms/api/v0/oxidized
scheme: https
secure: false
map:
model: os
group: group
headers:
X-Auth-Token: ‘TOKEN INFO’
model_map:
cisco: ios
juniper: junos
unifi: airos
ciscosb: ciscosmb
groups:
default:
hooks:
post-commit:
type: exec
events: [node_success, post_store]
cmd: ‘cd /root/.config/oxidized/devices.git && git push -f -q /root/.config/oxidized/devices.git master’
**Not too sure about the config above though
Librenms config:
Oxidized configuration
$config[‘oxidized’][‘enabled’] = TRUE;
$config[‘oxidized’][‘url’] = ‘http://OXIDIZEDSERVERIP:8843’;
$config[‘oxidized’][‘features’][‘versioning’] = true;
$config[‘oxidized’][‘group_support’] = true;
$config[‘oxidized’][‘default_group’] = ‘default’;
$config[‘oxidized’][‘reload_nodes’] = true;
$config[‘oxidized’][‘ignore_os’] = array(‘linux’,‘windows’);
$config[‘oxidized’][‘ignore_types’] = array(‘server’,‘power’);
| LibreNMS | 1.52-70-gf3ba894 |
| DB Schema | 2019_05_30_225937_device_groups_rewrite (135) |
| PHP | 7.2.16 |
| MySQL | 5.5.52-MariaDB |
| RRDTool | 1.4.8 |
| SNMP | NET-SNMP 5.7.2 |
[OK] Composer Version: 1.9.0
[WARN] Your install is over 24 hours out of date, last update: Sun, 23 Jun 2019 05:29:12 +0000
