Hello!
We upgraded OS to Ubuntu 22.04.3 and are struggling to get oxidized to work.
Due to this error we are unable to see the configuration of this device:
root@:/usr/local/bin# sudo systemctl status oxidized
● oxidized.service - Oxidized - Network Device Configuration Backup Tool
Loaded: loaded (/lib/systemd/system/oxidized.service; enabled; vendor preset: enabled)
Active: activating (auto-restart) (Result: exit-code) since Thu 2024-02-08 12:45:39 CET; 1min 14s ago
Process: 521840 ExecStart=/usr/local/bin/oxidized (code=exited, status=203/EXEC)
Main PID: 521840 (code=exited, status=203/EXEC)
CPU: 2ms
Feb 08 12:45:39 systemd[521840]: oxidized.service: Failed at step EXEC spawning /usr/local/bin/oxidized: No such file or directory
Feb 08 12:45:39 systemd[1]: oxidized.service: Main process exited, code=exited, status=203/EXEC
Feb 08 12:45:39 systemd[1]: oxidized.service: Failed with result ‘exit-code’.
root@:/usr/local/bin# date
Thu Feb 8 12:46:58 PM CET 2024
root@:/usr/local/bin# cat oxidized
#!/usr/bin/ruby2.7
This file was generated by RubyGems.
The application ‘oxidized’ is installed as part of a gem, and
this file is here to facilitate running it.
require ‘rubygems’
version = “>= 0.a”
str = ARGV.first
if str
str = str.b[/\A_(.*)_\z/, 1]
if str and Gem::Version.correct?(str)
version = str
ARGV.shift
end
end
if Gem.respond_to?(:activate_bin_path)
load Gem.activate_bin_path(‘oxidized’, ‘oxidized’, version)
else
gem “oxidized”, version
load Gem.bin_path(“oxidized”, “oxidized”, version)
end
Could someone please suggest what action is needed?
Thank you.
