I’m having an issue with Oxidized where it’s not using the group IP and credentials when trying to establish an SSH connection. Instead, it’s trying to log in with the default username and without an IP address.
Here’s the relevant part of my Oxidized configuration:
resolve_dns: false
interval: 3600
use_syslog: false
debug: false
threads: 30
use_max_threads: false
timeout: 20
retries: 3
next_adds_job: false
vars: {}
group_map:
default: defaultgrp
models: {}
pid: "/home/oxidized/.config/oxidized/pid"
crash:
directory: "/home/oxidized/.config/oxidized/crashes"
hostnames: false
stats:
history_size: 10
input:
default: ssh
debug: false
ssh:
auth_methods: [ "password", "keyboard-interactive" ]
secure: false
keys: false
ftp:
passive: true
utf8_encoded: true
rest: 192.168.20.151:8888
log: "/home/oxidized/.config/oxidized/log"
output:
default: git
git:
user: Oxidized
email: [email protected]
repo: "/home/oxidized/.config/oxidized/configs.git"
source:
default: http
debug: false
insecure: true
secure: false
scheme: http
http:
url: http://192.168.20.151/api/v0/oxidized
insecure: true
secure: false
map:
model: os
groups: group
ip: ip
headers:
X-Auth-Token: '6843bb25c953f75aa8d0a0b7e61b013d'
groups:
defaultgrp: #default group specified in Librenms, used as fallback
username: defaultuser
password: defaultpass
model: ios
cisco-ios: #group that all the cisco routers are gonna be in for backups
username: oxidizeduser
password: hidden.for@reason
model: ios
model_map:
juniper: junos
cisco: ios
microtik: routeros
I can reach LibreNMS. Here’s the response from the LibreNMS API:
"hostname": "192.168.1.153",
"os": "ios",
"ip": "192.168.1.153",
"group": "cisco-ios"
When Oxidized tries to establish an SSH connection, I get the following error in the logs:
I, [2023-11-26T19:04:48.782834 #951] INFO -- : Oxidized starting, running as pid 951
I, [2023-11-26T19:04:48.891116 #951] INFO -- : lib/oxidized/nodes.rb: Loading nodes
I, [2023-11-26T19:04:49.818590 #951] INFO -- : lib/oxidized/nodes.rb: Loaded 1 nodes
W, [2023-11-26T19:04:53.823978 #951] WARN -- : raised Net::SSH::AuthenticationFailed with msg "Authentication failed for user username@"
W, [2023-11-26T19:04:54.162565 #951] WARN -- : / status no_connection, retry attempt 1
W, [2023-11-26T19:04:56.823432 #951] WARN -- : raised Net::SSH::AuthenticationFailed with msg "Authentication failed for user username@"
W, [2023-11-26T19:04:57.165709 #951] WARN -- : / status no_connection, retry attempt 2
W, [2023-11-26T19:04:59.827404 #951] WARN -- : raised Net::SSH::AuthenticationFailed with msg "Authentication failed for user username@"
W, [2023-11-26T19:05:00.169843 #951] WARN -- : / status no_connection, retry attempt 3
W, [2023-11-26T19:05:02.836023 #951] WARN -- : raised Net::SSH::AuthenticationFailed with msg "Authentication failed for user username@"
W, [2023-11-26T19:05:03.173508 #951] WARN -- : / status no_connection, retries exhausted, giving up
As you can see, Oxidized is trying to log in with the username username
Any help would be greatly appreciated. Good documentation on the integration with LibreNMS is hard to find.
Thank you!
