So i have everything setup and working now Oxidized wise, but in the debug logs im not sure what to look for that may tell me why the configs arent shown in the device config tab.
I have librenms configured for oxidized API correctly based on the config and the token auth is correct for the librenms api and no errors show when i start and keep oxidized running. The only issue i see is when i input the localhost:8888 in the librenms api URL it’s always red outlined and doesn’t save/show the address i entered when i leave and go back to the oxidized tab.
Here is my config: https://pastebin.com/aMMsTBCU
Here is the debug output: https://drive.google.com/open?id=1NU-ma-xmDq039B4nOg4fi6TeWjibilIK
I don’t see what isn’t working or how i should configure it to work correctly. Theres tons of walk through for this and it seems every one is slightly different lol.
EDIT/UPDATE: So oddly enough the issue was in the External Config for Oxidized, i had to add http:// instead of just localhost:8888
