Oxidized trigger by syslog - Mikrotik
Hi
I am trying to get oxidized to pull config after a config change on mikrotik.
I have simplified my regex as much as i can, since i struggle wrapping my head around regex in general… Using rsyslog - updates fine into libre
Log message (From wireshark): system,info AP1: device changed by admin
Config string: (using a dummy script to touch a file, if i get a match)
$config['os']['routeros']['syslog_hook'][] = Array('regex' => '/changed by/', 'script' => '/opt/librenms/scripts/z.sh');
It is not matching - and i am at a loss on how to debug
i also restart rsyslog service between every change - (also syslog service, just in case)
Is the syslog received by LibreNMS?
What’s the script for?
The script is something that just “touch zworks” - creates a empty file to indicate that the hook triggered. Others has used this method to verify hook trigger.
Yes, syslog works fine.
