Hi
I’ve had Oxidized happily trucking away for a few years with our homogeneous Procurve environment, but now we’ve added a bunch of ArubaCX switches, and I’m having trouble getting Oxidized to work with two OS types. Can anyone offer any insight?
Crash file look like this:
2023-06-01 22:15:23 UTC
uninitialized constant Aoscx::Refinements [NameError]
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/model/aoscx.rb:2:in `<class:Aoscx>'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/model/aoscx.rb:1:in `<top (required)>'
/usr/lib/ruby/2.7.0/rubygems/core_ext/kernel_require.rb:92:in `require'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/manager.rb:9:in `load'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/manager.rb:60:in `loader'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/manager.rb:47:in `add_model'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/node.rb:170:in `resolve_model'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/node.rb:22:in `initialize'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:21:in `new'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:21:in `block (2 levels) in load'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:16:in `each'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:16:in `block in load'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:130:in `synchronize'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:130:in `with_lock'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:10:in `load'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/nodes.rb:125:in `initialize'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/core.rb:14:in `new'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/core.rb:14:in `initialize'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/core.rb:4:in `new'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/cli.rb:13:in `run'
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/bin/oxidized:8:in `<top (required)>'
/usr/local/bin/oxidized:23:in `load'
/usr/local/bin/oxidized:23:in `<main>'
Config look like this:
username: manager
password: password
model: procurve
log: /home/oxidized/.config/oxidized/logs/log
resolve_dns: false
interval: 3600
use_syslog: false
debug: true
threads: 30
timeout: 20
retries: 3
rest: 127.0.0.1:8888
next_adds_job: false
models:
procurve:
username: manager
password: password
ssh_port: 22
aoscx:
username: admin
password: password
ssh_port: 22
groups:
procurve:
username: manager
password: password
model: procurve
aoscx:
username: admin
password: password
model: aoscx
vars:
auth_methods: ["password"]
pid: "/home/oxidized/.config/oxidized/pid"
crash:
directory: "/home/oxidized/.config/oxidized/crash"
hostnames: false
stats:
history_size: 10
input:
default: ssh
debug: true
ssh:
secure: false
utf8_encoded: true
output:
default: git
debug: true
git:
user: oxidized
email : [email protected]
repo: /home/oxidized/.config/oxidized/deviceconfigs/default.git
source:
default: csv
csv:
file: "/home/oxidized/.config/oxidized/router.db"
delimiter: !ruby/regexp /:/
map:
ip: 0
model: 1
group: 2
model_map:
cisco: ios
juniper: junos
aoscx: aoscx
router.db just has two test entries for a 6000 CX and a Procurve
172.27.1.1:aoscx:aoscx
172.27.1.254:procurve:procurve
/var/lib/gems/2.7.0/gems/oxidized-0.28.0/lib/oxidized/model/aoscx.rb looks like this:
class Aoscx < Oxidized::Model
using Refinements
# previous command is repeated followed by "\eE", which sometimes ends up on last line
# ssh switches prompt may start with \r, followed by the prompt itself, regex ([\w\s.-]+[#>] ), which ends the line
# telnet switchs may start with various vt100 control characters, regex (\e\[24;[0-9][hH]), follwed by the prompt, followed
# by at least 3 other vt100 characters
prompt /(^\r|\e\[24;[0-9][hH])?([\w\s.-]+[#>] )($|(\e\[24;[0-9][0-9]?[hH]){3})/
comment '! '
# replace next line control sequence with a new line
expect /(\e\[1M\e\[\??\d+(;\d+)*[A-Za-z]\e\[1L)|(\eE)/ do |data, re|
data.gsub re, "\n"
end
# replace all used vt100 control sequences
expect /\e\[\??\d+(;\d+)*[A-Za-z]/ do |data, re|
data.gsub re, ''
end
expect /Press any key to continue(\e\[\??\d+(;\d+)*[A-Za-z])*$/ do
send ' '
end
expect /Enter switch number/ do
send "\n"
end
cmd :all do |cfg|
cfg = cfg.cut_both
cfg = cfg.gsub /^\r/, ''
# Additional filtering for elder switches sending vt100 control chars via telnet
cfg.gsub! /\e\[\??\d+(;\d+)*[A-Za-z]/, ''
# Additional filtering for power usage reporting which obviously changes over time
cfg.gsub! /^(.*AC [0-9]{3}V\/?([0-9]{3}V)?) *([0-9]{1,3}) (.*)/, '\\1 <removed> \\4'
cfg
end
cmd :secret do |cfg|
cfg.gsub! /^(snmp-server community) \S+(.*)/, '\\1 <secret hidden> \\2'
cfg.gsub! /^(snmp-server host \S+) \S+(.*)/, '\\1 <secret hidden> \\2'
cfg.gsub! /^(radius-server host \S+ key) \S+(.*)/, '\\1 <secret hidden> \\2'
cfg.gsub! /^(radius-server key).*/, '\\1 <configuration removed>'
cfg.gsub! /^(tacacs-server host \S+ key) \S+(.*)/, '\\1 <secret hidden> \\2'
cfg.gsub! /^(tacacs-server key).*/, '\\1 <secret hidden>'
cfg
end
cmd 'show version' do |cfg|
comment cfg
end
cmd 'show environment' do |cfg|
cfg.gsub! /^(LC.*\s+)\d+\s+$/, '\\1<hidden>'
cfg.gsub! /^(\d\/\d\/\d.*\s+)\d+\s+$/, '\\1<hidden>'
cfg.gsub! /^(\d+\/\S+\s+\S+\s+)\d+\.\d+\s+C(.*)/, '\\1<hidden>\\2'
cfg.gsub! /^(LC.*\s+)\d+\.\d+\s+(C.*)$/, '\\1 <hidden> \\2'
comment cfg
end
cmd 'show module' do |cfg|
comment cfg
end
cmd 'show interface transceiver' do |cfg|
comment cfg
end
cmd 'show system | exclude "Up Time" | exclude "CPU" | exclude "Memory"' do |cfg|
comment cfg
end
cmd 'show running-config'
cfg :telnet do
username /Username:/
password /Password:/
end
cfg :telnet, :ssh do
# preferred way to handle additional passwords
if vars :enable
post_login do
send "enable\n"
cmd vars(:enable)
end
end
post_login 'no page'
pre_logout "exit"
end
cfg :ssh do
pty_options(chars_wide: 1000)
end
end
