Oxidized - Web install fails
Hi all
I am having an issue getting oxidized web installed on the following box:
Ubuntu 16.04.6 LTS
After a bit of jargon the the following is the output from the get install oxidized-web command:
make failed, exit code 2
Any ideas of whats wrong
Thx
Do you have g++ installed?
#https://github.com/ytti/oxidized/pull/1684
Yes - it is installed…
Probably another dependency needs installing, What Ruby version are you running?
Can you show full output of the error.
