I am working with the FreeBSD maintainer to package LibreNMS 1.41 and we are hitting problems.
These issues did not arise with 1.35, the latest version ported to FreeBSD.
I hope to document the issues in case the developers wish to change the way LibreNMS is doing things. I wish to highlight the problems associated with packaging the application. Not every environment permits the use of git to update or the use of composer to install the dependencies. We are looking at finding a way to create a package given those constraints.
One issuer with running composer at install time, there are many scripts installed by composer which assume path names. FreeBSD calls these SHEBANG fixes. e.g. stuff might be in /usr/local/bin etc, not /bin or /sbin. Everything not related to the base operating systems goes into /usr/local/ not /.
We are trying to find a way to get around that by running composer at package building time. We need to consider the license issues of distributing a tarball containing the vendor code.
I’ll keep you updated as things progress. Thank you.
@dvl My question is what were you doing before when we shipped all this in the git folder? 1.35 used composer autoload, it was just in the git repository. (I’m not tying to start a disagreement, I legitimately want to know).
As far as I know nothing installed by composer uses fixed paths. Also, everything installed by composer should reside inside the vendor folder, inside the librenms folder.
If it makes it easier, I can run composer and upload a tar ball for you…
I think the major difference is the 1.35 tarball contained a vendor directory in the tarball:
[[email protected]:~/tmp/librenms-1.35/vendor] $ ls
amenadiel composer easybook palanik php-amqplib ramsey slim tecnickcom
autoload.php dapphp ezyang pear phpmailer rmccue symfony xjtuwangke
I think that’s the difference. It was provided and we just used that. We could patch it correctly as it was just there at install time.
The difference now is we can’t download the tarball, extract the code, patch it and supply it as a package. NOTE: these are not manual steps, they are complete automated by the FreeBSD port tree.
When you run composer, what command are you running? Perhaps we can just specify that in our Makefile.
fatal: not a git repository (or any parent up to mount point /usr)
Stopping at filesystem boundary (GIT_DISCOVERY_ACROSS_FILESYSTEM not set).
Installing dependencies (including require-dev) from lock file
Your requirements could not be resolved to an installable set of packages.
Problem 1
- The requested PHP extension ext-mysqli * is missing from your system. Install or enable PHP’s mysqli extension.
Problem 2
- The requested PHP extension ext-session * is missing from your system. Install or enable PHP’s session extension.
Problem 3
- The requested PHP extension ext-gd * is missing from your system. Install or enable PHP’s gd extension.
Problem 4
- Installation request for amenadiel/jpgraph 3.6.19 -> satisfiable by amenadiel/jpgraph[3.6.19].
- amenadiel/jpgraph 3.6.19 requires ext-gd * -> the requested PHP extension gd is missing from your system.
Problem 5
- Installation request for nikic/php-parser v3.1.5 -> satisfiable by nikic/php-parser[v3.1.5].
- nikic/php-parser v3.1.5 requires ext-tokenizer * -> the requested PHP extension tokenizer is missing from your system.
Problem 6
- Installation request for phpunit/php-token-stream 1.4.12 -> satisfiable by phpunit/php-token-stream[1.4.12].
- phpunit/php-token-stream 1.4.12 requires ext-tokenizer * -> the requested PHP extension tokenizer is missing from your system.
Problem 7
- Installation request for phpunit/php-code-coverage 4.0.8 -> satisfiable by phpunit/php-code-coverage[4.0.8].
- phpunit/php-code-coverage 4.0.8 requires ext-xmlwriter * -> the requested PHP extension xmlwriter is missing from your system.
Problem 8
- Installation request for squizlabs/php_codesniffer 2.9.1 -> satisfiable by squizlabs/php_codesniffer[2.9.1].
- squizlabs/php_codesniffer 2.9.1 requires ext-tokenizer * -> the requested PHP extension tokenizer is missing from your system.
Problem 9
- psy/psysh v0.9.5 requires nikic/php-parser ~1.3|~2.0|~3.0|~4.0 -> satisfiable by nikic/php-parser[v3.1.5].
- Installation request for psy/psysh v0.9.5 -> satisfiable by psy/psysh[v0.9.5].
To enable extensions, verify that they are enabled in your .ini files:
- /usr/local/etc/php/ext-20-ctype.ini
- /usr/local/etc/php/ext-20-curl.ini
- /usr/local/etc/php/ext-20-dom.ini
- /usr/local/etc/php/ext-20-filter.ini
- /usr/local/etc/php/ext-20-hash.ini
- /usr/local/etc/php/ext-20-intl.ini
- /usr/local/etc/php/ext-20-json.ini
- /usr/local/etc/php/ext-20-mbstring.ini
- /usr/local/etc/php/ext-20-openssl.ini
- /usr/local/etc/php/ext-20-simplexml.ini
- /usr/local/etc/php/ext-20-xml.ini
- /usr/local/etc/php/ext-30-phar.ini
You can also run php --ini inside terminal to see which files are used by PHP in CLI mode.
I think my next step is to create a librenms-vendor-1.41.01.tar.gz and host it somewhere. I suspect I can do this on the FreeBSD infrastructure. These steps would be necessary for each new release I assume.
I will report back again after I try building with that I have.
This morning, I incorporated the new vendor directory into my working copy of the FreeBSD port. It builds, and I see that after installing it, I have some work to do with respect to dependencies. I suspect I have to review Problems 1…9 listed above. I’ll come back to this soon…
FWIW, this is what I get when I browse to the new website:
Error: Missing dependencies! Run the following command to fix:
Of note, that is not the exact command I ran to build the vendor directory. Should my steps be amended to include --no-dev?
[[email protected]:~/librenms] $ ./scripts/composer_wrapper.php install --no-dev
Package operations: 64 installs, 0 updates, 0 removals
- Installing symfony/dotenv (v3.4.13): Loading from cache
- Installing amenadiel/jpgraph (3.6.20): Loading from cache
- Installing dapphp/radius (2.5.4): Loading from cache
- Installing doctrine/inflector (v1.1.0): Loading from cache
- Installing doctrine/instantiator (1.0.5): Loading from cache
- Installing easybook/geshi (v1.0.8.19): Loading from cache
- Installing erusev/parsedown (1.7.1): Loading from cache
- Installing ezyang/htmlpurifier (v4.10.0): Loading from cache
- Installing vlucas/phpdotenv (v2.4.0): Loading from cache
- Installing symfony/css-selector (v3.4.13): Loading from cache
- Installing tijsverkoyen/css-to-inline-styles (2.2.1): Loading from cache
- Installing symfony/polyfill-mbstring (v1.8.0): Loading from cache
- Installing symfony/var-dumper (v3.4.13): Loading from cache
- Installing symfony/routing (v3.2.14): Loading from cache
- Installing symfony/process (v3.4.13): Loading from cache
- Installing symfony/polyfill-ctype (v1.8.0): Loading from cache
- Installing paragonie/random_compat (v2.0.17): Loading from cache
- Installing symfony/polyfill-php70 (v1.8.0): Loading from cache
- Installing symfony/http-foundation (v3.4.13): Loading from cache
- Installing symfony/event-dispatcher (v3.4.13): Loading from cache
- Installing psr/log (1.0.2): Loading from cache
- Installing symfony/debug (v3.4.13): Loading from cache
- Installing symfony/http-kernel (v3.4.13): Loading from cache
- Installing symfony/finder (v3.4.13): Loading from cache
- Installing symfony/console (v3.4.13): Loading from cache
- Installing swiftmailer/swiftmailer (v5.4.9): Loading from cache
- Installing ramsey/uuid (3.8.0): Loading from cache
- Installing symfony/translation (v3.2.14): Loading from cache
- Installing nesbot/carbon (1.32.0): Loading from cache
- Installing mtdowling/cron-expression (v1.2.1): Loading from cache
- Installing monolog/monolog (1.23.0): Loading from cache
- Installing league/flysystem (1.0.45): Loading from cache
- Installing laravel/framework (v5.4.36): Loading from cache
- Installing fico7489/laravel-pivot (2.0.6): Loading from cache
- Installing guzzlehttp/promises (v1.3.1): Loading from cache
- Installing psr/http-message (1.0.1): Loading from cache
- Installing guzzlehttp/psr7 (1.4.2): Loading from cache
- Installing guzzlehttp/guzzle (6.3.3): Loading from cache
- Installing influxdb/influxdb-php (1.14.7): Loading from cache
- Installing jakub-onderka/php-console-color (0.1): Loading from cache
- Installing nikic/php-parser (v3.1.5): Loading from cache
- Installing jakub-onderka/php-console-highlighter (v0.3.2): Loading from cache
- Installing dnoegel/php-xdg-base-dir (0.1): Loading from cache
- Installing psy/psysh (v0.9.6): Loading from cache
- Installing laravel/tinker (v1.0.7): Loading from cache
- Installing laravel/laravel (v5.4.30): Loading from cache
- Installing myclabs/deep-copy (1.7.0): Loading from cache
- Installing oriceon/toastr-5-laravel (dev-master 8a03502): Cloning 8a03502cc7 from cache
- Installing slim/slim (2.6.3): Loading from cache
- Installing palanik/corsslim (v1.1.0): Loading from cache
- Installing pear/console_color2 (0.1.2): Loading from cache
- Installing pear/console_table (v1.3.1): Loading from cache
- Installing php-amqplib/php-amqplib (v2.0.2): Loading from cache
- Installing webmozart/assert (1.3.0): Loading from cache
- Installing phpdocumentor/reflection-common (1.0.1): Loading from cache
- Installing phpdocumentor/type-resolver (0.4.0): Loading from cache
- Installing phpdocumentor/reflection-docblock (3.3.2): Loading from cache
- Installing phpmailer/phpmailer (v5.2.26): Loading from cache
- Installing phpunit/php-token-stream (1.4.12): Loading from cache
- Installing rmccue/requests (v1.7.0): Loading from cache
- Installing symfony/yaml (v2.8.43): Loading from cache
- Installing tecnickcom/tcpdf (6.2.17): Loading from cache
- Installing wpb/string-blade-compiler (3.4.x-dev 30c974a): Cloning 30c974a305 from cache
- Installing xjtuwangke/passwordhash (dev-master a7bcd97): Cloning a7bcd9705a from cache
Generating autoload files
> LibreNMS\ComposerHelper::postInstall
> Illuminate\Foundation\ComposerScripts::postInstall
> php artisan optimize
Generating optimized class loader
The compiled services file has been removed.
After installing and restarting Apache, the website reports:
### Error: Missing dependencies! Run the following command to fix:
Running validate.php:
$ ./validate.php
PHP Warning: Module 'tokenizer' already loaded in Unknown on line 0
PHP Warning: Module 'snmp' already loaded in Unknown on line 0
PHP Warning: Module 'session' already loaded in Unknown on line 0
PHP Warning: Module 'mysql' already loaded in Unknown on line 0
PHP Warning: Module 'mcrypt' already loaded in Unknown on line 0
PHP Warning: Module 'json' already loaded in Unknown on line 0
PHP Warning: Module 'gd' already loaded in Unknown on line 0
PHP Warning: Module 'filter' already loaded in Unknown on line 0
PHP Warning: Module 'ctype' already loaded in Unknown on line 0
PHP Fatal error: Class 'LibreNMS\Validator' not found in /usr/local/www/librenms/validate.php on line 96
LibreNMS |
DB Schema | ?
PHP | 5.6.37
MySQL | ?
RRDTool | 1.7.0
SNMP | NET-SNMP 5.7.3
FYI, the vendor directory contains:
$ ls vendor
amenadiel composer easybook guzzlehttp palanik php-amqplib psr rmccue symfony xjtuwangke
autoload.php dapphp ezyang influxdb pear phpmailer ramsey slim tecnickcom
The class is there:
$ ls LibreNMS/
Alert DB OS RRDRecursiveFilterIterator.php queuemanager.py
Alerting Device OS.php Util service.py
Authentication Exceptions ObjectCache.php ValidationResult.php
Component.php IRCBot.php Plugins.php Validations
ComposerHelper.php Interfaces Proc.php Validator.php
Config.php Model.php RRD __init__.py
