Hi Guys,
After the alert webui was upgraded, I don’t see any option how can I specify level of packet loss, please see the image below, it shows two options only yes or no
Hi Guys,
idk why its doing that but if you look in global settings you can see the macro, maybe you could manually make the alert rule.
Hi Kelvin,
Looks like it’s not working as expected, what if I use fping check from nagios plugin, it gives me packet loss statistics, in that case what service check trigger I should use in alerts?
