Navigate to the NMS url via https
You will see the visual problem with the layout not displaying correctly, like it does with the http version.
- The output of
./validate.php
| LibreNMS | 22.10.0-96-g0e9bb0407 (2022-11-08T17:22:37+00:00) |
| DB Schema | 2022_08_15_084507_add_rrd_type_to_wireless_sensors_table (248) |
| PHP | 8.1.11 |
| Python | 3.6.8 |
| Database | MariaDB 10.3.35-MariaDB |
| RRDTool | 1.7.0 |
| SNMP | 5.8 |
[OK] Composer Version: 2.4.4
[OK]
[FAIL] Time between this server and the mysql database is off
Mysql time 2022-11-09 13:50:18
PHP time 2022-11-09 12:50:18
Visiting with HTTPS:
I can’t for the life of me figure out why the css isn’t loading…
P.S I’m a new user so can only attach one image, so I’ve uploaded the one with the broken layout… the other image is basically the login page formatted correctly, when not visiting via https.
nginx config:
server {
listen 443 ssl http2;
server_name nms;
root /opt/librenms/html;
index index.php;
access_log /var/log/nginx/scripts.log scripts;
ssl_certificate /etc/nginx/ssl/nms.crt;
ssl_certificate_key /etc/nginx/ssl/nms.key;
charset utf-8;
gzip on;
location / {
location ~ [^/]\.php(/|$) {
fastcgi_pass unix:/run/php-fpm/librenms.sock;
fastcgi_split_path_info ^(.+\.php)(/.+)$;
include fastcgi.conf;
location ~ /\.(?!well-known).* {
deny all;
Regards,
Matt
