Hi Guys,
I understand that for this time, all alerts which are triggered on Librenms will trigger pager duty
So in that case what the purpose of Severity? if I use Critical or Warning, both will be sent to pager Duty
Hi Guys,
They are they there to help prioritize your alerts.
Like, a device down could be “Critical”.
A device using 60% memory could be a “Warning”
You can configure however you want.
But this priority won’t take any affect on pager duty alert ,as warning will also trigger the Pager duty
No, that I have ever seen…
If you don’t want an alert to trigger pager duty or any other transport. You could set the alert to “mute” and this will only show the alert in the web UI of librenms.
