My palo alto firewalls lately had an issue after which i decided to monitor also the packet buffer & connection per seconds on our firewalls.
I found the below URL showing the extended SNMP support which PAN firewalls can support.
https://docs.paloaltonetworks.com/pan-os/8-0/pan-os-new-features/management-features/extended-snmp-support
So i want to configure this for PANOS-8.1 version, for this there’s a procedure -
A. https://docs.paloaltonetworks.com/resources/snmp-mib-files - from here the MIB file needs to be downloaded
B. https://docs.paloaltonetworks.com/pan-os/7-1/pan-os-admin/monitoring/use-an-snmp-manager-to-explore-mibs-and-objects – > this one shows how to load these MIBs.
I am using Librenms to monitor all my network devices and i am unable to find a way to make this working.
I would really appreciate if someone can guide me with this.
Regards,
Nishad
