Parameters for nrpe_check Win-NRPE:Memory with NSClient++
Hello dear LibreNMS community,
I have now tried different parameters for the nrpe_check with the nsclient++ for our SQL server.
I want to get a warning state at about 95% usage and a critical state at 100% usage.
The default parameters look like this:
-n -2 -c CheckMem
It works, but the warning and critical state is set too low for an SQL server.
I tried things like:
-n -2 -c CheckMem -w 95 -c 99
After that the check does not work anymore.
I hope you can help me.
Regards
