In our network, he have routers called ISG/BNG which are responsible from termination PPPoE sessions from customers. On the router these sessions are treated as virtual interfaces, so when i add these routers to librenms, they are also being processed. Im talking about 20k-30k interfaces, so when i add them up, CPU of the routers are getting %90 values.
When i checked the forum, i see that the only sensible solution is excluding them via “per port polling” feature. But i see that this feature is still “experimental” so i just wanted to if there is any other solution to overcome my problem. Or if im going to proceed with “per port polling” might i face with another issue since its experimental.
Thanks for your answers.
