Hello Team,
I have included Syslog in my librenms. But all the users are able to view those logs. My requirement is to make the syslog available only to selected users. How can i manage these priviledge levels. Please suggest.
Regards
Hello Team,
Regards
You can assign users permissions for specific devices, they will then only be able to see syslogs from those.
I’m guessing you want a global “read-syslog” permission, which is - as far as I’m aware - not implemented at the moment.
Hello Florian,
You got me right. Is there any way to make this possible.
Sure, you can always submit a pull request and then people will discuss it and if it passes, the lead devs will merge it in.
