Phantom ports
I have two ports showing in the list of down ports that appear to be attached to a deleted device. The link is like /device/device=139/tab=port/port=11685/ and I’ve confirmed both in the web UI and manually with a mysql query that no such device ID exists. (404 on /device/139 in the web, “Empty set (0.001 sec)” on query “SELECT device_id FROM devices WHERE device_id=139”).
Is it safe to do a “DELETE FROM ports WHERE device_id=139” and should I be cleaning up any other tables? It does appear there’s data by port_id in ports_statistics as well. Is there an easier/safer way to clean this up?
I do run validate.php every few days by hand. I have distributed polling setup. This is the mysql host:
librenms@nms:~$ ./validate.php
LibreNMS  | 25.4.0-17-geea4b297b (2025-04-21T15:59:22-06:00)
DB Schema | 2025_03_19_205700_fix_ospfv3_ports_table (331)
PHP       | 8.3.6
Python    | 3.12.3
Database  | MariaDB 10.11.11-MariaDB-0ubuntu0.24.04.2
SNMP      | 5.9.4.pre2
[OK]    Composer Version: 2.8.8
[OK]    Redis is functional
librenms@nms:~$
You might have a look at: CLI Scripts - LibreNMS Docs
If you’ve confirmed the port is orphaned it shouldn’t really hurt to delete it from the DB but there’s the possibility you’re leaving behind a rrd file for the port as well. May not matter if you have rrd_purge enabled as it should get cleaned up eventually.
Thanks, that worked. The section in the documentation is titled purge-ports.php (plural) but the actual script is purge-port.php (singular) for anyone else needing this solution.
