PHP 8.4 Upgrade Issue- CPU Maxed Out
Initial Issue:
LibreNMS upgraded automatically, and I was on PHP 8.2.1, which broke my instance. I had to upgrade PHP manually and moved to (latest version) 8.4.6 using a guide from CyberBunny found here on the forums.
Current Issue:
Since the upgrade to 8.4.6, the CPU eventually maxes out (15-30 mins) and crashes the VM.
LibreNMS 25.4.0-12-g234fa3277d (2025-04-17T01:21:54-05:00)
DB Schema 2025_03_19_205700_fix_ospfv3_ports_table (331)
PHP 8.4.6
Python 3.10.12
Database MariaDB 10.6.21-MariaDB-0ubuntu0.22.04.2
SNMP 5.9.1
[OK] Composer Version: 2.8.8
[OK] Dispatcher Service has been used, but not recently
Information about our environment/other notes:
  • We do not use the Dispatch Service, but instead use Cron for the pollers.
  • We have 69 devices in our environment.
  • Poller frequency is set to 60 seconds.
  • This configuration in our environment used to work with half the CPUs (had 6 vCPUs and now, even at 12, it’s crashing).
  • Python Poller is set to 6 instead of 16.
  • ./daily.sh does not fix this and runs without issues.
  • /settings/system/scheduledtasks is all set to “Legacy.”
  • I have not investigated the performance documentation yet.(Performance - LibreNMS Docs)
As a side note, my friend who works at a different organization manually upgraded from 8.2.1 PHP to 8.3, and he is monitoring 587 devices and is utilizing 16 CPUs. Something is causing issues here and I’m not sure if its PHP or something entirely different.
Thanks,
Michael
Here is a screenshot of the resource monitor from VMware. I was also watching HTOP for 20 minutes in the CLI, and the CPU never hit anything I would consider high. This was very sudden; everything was running just fine, then I lost CLI access, the website crashed, and it was after this happened that the CPU started to climb.
I finally found the issue, and it’s embarrassing but also random.
1st- Syslogs were not working on my VM when I would tail them. So I had to reinstall rsyslog.
-sudo apt install rsyslog
-sudo systemctl enable --now rsyslog
Then I watched the Syslog output in /var/syslog. When going through the logs, I caught the below. It appeared that as part of a GUI setup or Ubuntu update, gnome/hibernation was kicking in on this VM, causing the machine to halt/crash, the CPU to spike, and the machine to be rendered unusable through SSH or GUI.
May 9 09:44:19 ubuntu NetworkManager[931]: [1746801859.2244] manager: sleep: sleep requested (sleeping: no enabled: yes)
May 9 09:44:19 ubuntu ModemManager[1041]: [sleep-monitor-systemd] system is about to suspend
May 9 09:44:19 ubuntu NetworkManager[931]: [1746801859.2246] manager: NetworkManager state is now ASLEEP
The fix:
-sudo systemctl mask sleep.target suspend.target hibernate.target hybrid-sleep.target
-sudo apt purge gnome-shell gnome-session gdm3
Under /etc/sysemd/logind.conf, I placed the below uncommented out. This should help with other sleep-related settings in Ubuntu.
HandleLidSwitch=ignore
HandleLidSwitchDocked=ignore
HandleSuspendKey=ignore
HandleHibernateKey=ignore
IdleAction=ignore
I then restarted systemd-logind to apply these settings:
-sudo systemctl restart systemd-logind
The VM has been up for days now without issue. The issue has been resolved.
