Greetings! New User here. I have been using Librenms for a few months now and it has been great…until last week.
Running on Debian Stretch with 4GB of RAM.
I am getting the dreaded blank pages in the Web GUI. The header is still there (missing a few links though). I have combed the community for people with similar issues and have tried everything I am comfortable with with no resolve.
Here is the error that is logged under ./logs/error_log:
2018/11/14 10:23:28 [error] 10575#10575: *4 FastCGI sent in stderr: “PHP message: PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 8192 bytes) in /opt/librenms/vendor/laravel/framework/src/Illuminate/Database/Connection.php on line 325
PHP message: PHP Fatal error: Allowed memory size of 134217728 bytes exhausted (tried to allocate 32768 bytes) in /opt/librenms/vendor/symfony/debug/Exception/FatalErrorException.php on line 1” while reading response header from upstream, client: 192.168.1.151, server: blah.blah.com, request: “GET /services/ HTTP/2.0”, upstream: “fastcgi://unix:/var/run/php/php7.0-fpm.sock:”, host: “blah.blah.com”, referrer: “https://blah.blah.com/devices/”
Here is ./validate.php output:
Component | Version |
LibreNMS | 1.45-34-gd3f5dc682 |
DB Schema | 270 |
PHP | 7.0.30-0+deb9u1 |
MySQL | 10.1.26-MariaDB-0+deb9u1 |
RRDTool | 1.6.0 |
SNMP | NET-SNMP 5.7.3 |
[OK] Composer Version: 1.7.3
Modified Files:
bootstrap/cache/.gitignore
storage/app/.gitignore
storage/app/public/.gitignore
storage/debugbar/.gitignore
storage/logs/.gitignore
The main things I have done so far is install php_mbstring and ran the “wrapper_compose.php install --no-dev” and uninstalled Phython 2.7 (I also have 3.5 installed). I increase the memory limit in php.ini from 128M to 1024MB. My issue just persists.
Suggestions?
Thanks!!!
