Php weathermap not updating after ./daily.sh
bash-4.2$ ./validate.php
LibreNMS 22.8.0-99-gfb489f6
DB Schema 2022_09_03_091314_update_ports_adsl_table_with_defaults (246)
PHP 7.4.30
Python 3.6.8
Database MariaDB 10.5.17-MariaDB
RRDTool 1.4.8
SNMP 5.7.2
[OK] Composer Version: 2.4.2
[OK]
[OK] MySQl and PHP time match
[WARN] PHP version 8.1 is the minimum supported version as of September, 2022. We recommend you update PHP to a supported version (8.1 suggested) to continue to receive updates. If you do not update PHP, LibreNMS will continue to function but stop receiving bug fixes and updates.
[FAIL] Python3 module issue found: 'Required packages: [‘PyMySQL!=1.0.0’, ‘python-dotenv’, ‘redis>=3.0’, ‘setuptools’, ‘psutil>=5.6.0’, ‘command_runner>=1.3.0’]
Package not found: The ‘command_runner>=1.3.0’ distribution was not found and is required by the application
pip3 install -r /opt/librenms/requirements.txt
bash-4.2$ ./discovery.php -h HOSTNAME -d | ./pbin.sh
Paste endpoint: https://p.libren.ms/api/create
title:
private: 1
expire: 0
https://p.libren.ms/view/83e349af
bash-4.2$ ./poller.php -h HOSTNAME -r -f -d | ./pbin.sh
title:
private: 1
expire: 0
https://p.libren.ms/view/423e4658
ive fixed the ./validate.php but the weathermap is still not updating
PHP 8.1.10
Python 3.6.8
RRDTool 1.4.8
SNMP 5.7.2
[OK]
There are 100 previous posts about this
