PKG Section
I’m using the Unix Agent on a mix of centos and ubuntu machines.
And have enabled the rpm plugin on the centos machines and the dpkg plugin on the ubuntu machines. The RPM plugin successfully displays on the Librenms under the pkg section for the server. But the Ubuntu servers pkg section doesn’t appear at all. I’ve created a session to the unix agent port and can see the <> data in the return message so i know its correctly being received by librenms. Is this a known bug or issue?
