I would like to do POE statistic.
I set this parametre in config.php :
$config[‘enable_ports_poe’] = 1;
When i do :
php poller.php -h sw-bonnegarde1-1.reseau.nantes.net -d -v -m ports
I see snmpwalk for MIB for poe:
exemple
SNMP[/usr/bin/snmpbulkwalk -v2c -c ‘public’ -OQUs -m CISCO-POWER-ETHERNET-EXT-MIB -M /opt/librenms/mibs:/opt/librenms/mibs/cisco udp:sw-bonnegarde1-1.reseau.nantes.net:161 cpeExtPsePortEntry]
[1.2] => Array
[pethPsePortAdminEnable] => true
[pethPsePortPowerPairsControlAbility] => false
[pethPsePortPowerPairs] => signal
[pethPsePortDetectionStatus] => deliveringPower
[pethPsePortPowerPriority] => low
[pethPsePortMPSAbsentCounter] => 0
[pethPsePortType] => Ieee PD
[pethPsePortPowerClassifications] => class2
[pethPsePortInvalidSignatureCounter] => 0
[pethPsePortPowerDeniedCounter] => 0
[pethPsePortOverLoadCounter] => 0
[pethPsePortShortCounter] => 0
[cpeExtPsePortEnable] => auto
[cpeExtPsePortDiscoverMode] => unknown
[cpeExtPsePortDeviceDetected] => false
[cpeExtPsePortIeeePd] => true
[cpeExtPsePortAdditionalStatus] => 00
[cpeExtPsePortPwrMax] => 15400
[cpeExtPsePortPwrAllocated] => 4100
[cpeExtPsePortPwrAvailable] => 4100
[cpeExtPsePortPwrConsumption] => 2889
[cpeExtPsePortMaxPwrDrawn] => 3682
[cpeExtPsePortEntPhyIndex] => 1006
[cpeExtPsePortPolicingCapable] => true
[cpeExtPsePortPolicingEnable] => off
[cpeExtPsePortPolicingAction] => deny
[cpeExtPsePortPwrManAlloc] => 0
RRD update :
Port Fa0/2: FastEthernet0/2 (10002 / #13768) HC HC HighSpeed dot3Duplex VLAN == 3080Using ifDescr as ifAliasFastEthernet0/2
ifInOctets (8839 B) 6.6061285500747 Bps 1338 secs
ifOutOctets (2242647 B) 1676.1188340807 Bps 1338 secs
ifInErrors (0 B) 0 Bps 1338 secs
ifOutErrors (0 B) 0 Bps 1338 secs
ifInUcastPkts (90 B) 0.067264573991031 Bps 1338 secs
ifOutUcastPkts (234 B) 0.17488789237668 Bps 1338 secs
ifInNUcastPkts (0 B) 0 Bps 1338 secs
ifOutNUcastPkts (0 B) 0 Bps 1338 secs
ifInDiscards (0 B) 0 Bps 1338 secs
ifOutDiscards (0 B) 0 Bps 1338 secs
ifInUnknownProtos (0 B) 0 Bps 1338 secs
ifInBroadcastPkts (1 B) 0.0007473841554559 Bps 1338 secs
ifOutBroadcastPkts (9941 B) 7.4297458893871 Bps 1338 secs
ifInMulticastPkts (11 B) 0.0082212257100149 Bps 1338 secs
ifOutMulticastPkts (3237 B) 2.4192825112108 Bps 1338 secs
bps(53.000bps/13.410kbps)bytes(8.630kB/2.140MB)pkts(67.260mpps/0.170pps)RRD[update /opt/librenms/rrd/sw-bonnegarde1-1.reseau.nantes.net/port-id13768.rrd N:8595131995:53767671013:0:0:27727508:35954042:U:U:0:6945:U:68335:69656619:175872:65590728]
RRDtool Output: OK u:0,00 s:0,00 r:3,24
RRD[update /opt/librenms/rrd/sw-bonnegarde1-1.reseau.nantes.net/port-id13768-poe.rrd N:U:U:U:U]
RRDtool Output: PoE SQL[UPDATE ports set poll_time =‘1500882717’,poll_prev =‘1500881379’,poll_period =‘1338’,ifLastChange =‘289994540’,ifInOctets =‘8595131995’,ifInOctets_prev =‘8595123156’,ifInOctets_rate =‘6.6061285500747’,ifInOctets_delta =‘8839’,ifOutOctets =‘53767671013’,ifOutOctets_prev =‘53765428366’,ifOutOctets_rate =‘1676.1188340807’,ifOutOctets_delta =‘2242647’,ifInErrors =‘0’,ifInErrors_prev =‘0’,ifInErrors_rate =‘0’,ifInErrors_delta =‘0’,ifOutErrors =‘0’,ifOutErrors_prev =‘0’,ifOutErrors_rate =‘0’,ifOutErrors_delta =‘0’,ifInUcastPkts =‘27727508’,ifInUcastPkts_prev =‘27727418’,ifInUcastPkts_rate =‘0.067264573991031’,ifInUcastPkts_delta =‘90’,ifOutUcastPkts =‘35954042’,ifOutUcastPkts_prev =‘35953808’,ifOutUcastPkts_rate =‘0.17488789237668’,ifOutUcastPkts_delta =‘234’ WHERE port_id = ‘13768’]
SQL[UPDATE ports_statistics set ifInNUcastPkts =‘0’,ifInNUcastPkts_prev =‘0’,ifInNUcastPkts_rate =‘0’,ifInNUcastPkts_delta =‘0’,ifOutNUcastPkts =‘0’,ifOutNUcastPkts_prev =‘0’,ifOutNUcastPkts_rate =‘0’,ifOutNUcastPkts_delta =‘0’,ifInDiscards =‘0’,ifInDiscards_prev =‘0’,ifInDiscards_rate =‘0’,ifInDiscards_delta =‘0’,ifOutDiscards =‘6945’,ifOutDiscards_prev =‘6945’,ifOutDiscards_rate =‘0’,ifOutDiscards_delta =‘0’,ifInUnknownProtos =‘0’,ifInUnknownProtos_prev =‘0’,ifInUnknownProtos_rate =‘0’,ifInUnknownProtos_delta =‘0’,ifInBroadcastPkts =‘68335’,ifInBroadcastPkts_prev =‘68334’,ifInBroadcastPkts_rate =‘0.0007473841554559’,ifInBroadcastPkts_delta =‘1’,ifOutBroadcastPkts =‘69656619’,ifOutBroadcastPkts_prev =‘69646678’,ifOutBroadcastPkts_rate =‘7.4297458893871’,ifOutBroadcastPkts_delta =‘9941’,ifInMulticastPkts =‘175872’,ifInMulticastPkts_prev =‘175861’,ifInMulticastPkts_rate =‘0.0082212257100149’,ifInMulticastPkts_delta =‘11’,ifOutMulticastPkts =‘65590728’,ifOutMulticastPkts_prev =‘65587491’,ifOutMulticastPkts_rate =‘2.4192825112108’,ifOutMulticastPkts_delta =‘3237’ WHERE port_id = ‘13768’]
2 updated
Whan I open Web GUI, I don’'t see statistique of this swith on Overview .
Cdlt,
