I don’t know why this happens to me
everything looks good here
if i use this command it changes to green for a few seconds but then turns red
/opt/librenms/cronic /opt/librenms/poller-wrapper.py 16
also
.daily.sh
Are you sure you didn’t modify the cron?
I was able to follow a series of steps in several places, I don’t know which one corrected the problem.
On the other hand, do you know if the prometheus integration extracts data from prometheus to librenms or sends it from libreNMS to prometheus?
