Poller Group ID - counting
LibreNMS 25.12.0 (2025-12-15T15:05:13+01:00)
DB Schema 2025_12_05_205509_devices_add_mtu_status (362)
PHP 8.3.6
Python 3.12.3
Database MariaDB 10.11.13-MariaDB-0ubuntu0.24.04.1
SNMP 5.9.4.pre2
[OK] Composer Version: 2.9.3
[INFO] Could not read cron files
I previously created several poller groups and later deleted them. Now I want to create new poller groups again.
The problem is that when I add a new poller group, the ID keeps increasing instead of starting from 1 or 2. I would like to recreate poller groups with IDs 1 and 2, but LibreNMS continues counting from the last deleted ID.
Is there a way to reset or reuse poller group IDs?
Do I need to clean something in the database, or is this behavior expected?
Thanks in advance for your help.
This is due to MySQL. We would never implement this in LibreNMS, but two ways you can fix it.
Set what you want directly in MySQL.
truncate the poller_groups table in MySQL, which will reset the auto ids.
