I finished installing LibreNMS as a Docker Image under UNRAID. Everything appears to be fine, except that polling is not working. If I run validate, I get this:
$ ./validate.php
Component | Version |
LibreNMS | 22.10.0 (2022-10-22T02:25:22-05:00) |
DB Schema | 2022_09_03_091314_update_ports_adsl_table_with_defaults (246) |
PHP | 8.0.24 |
Python | 3.10.5 |
Database | MariaDB 10.9.3-MariaDB-1:10.9.3+maria~ubu2204 |
RRDTool | 1.7.2 |
SNMP | 5.9.3 |
[OK]
[OK] MySQl and PHP time match
[FAIL] No active polling method detected
If I run poller.php manually, it appears to work fine. The same with discovery.php.
The pastebin link for both processes are:
https://p.libren.ms/view/ca8a5de2
https://p.libren.ms/view/bed7f2f9
