Hi everyone,
I have disabled a poller module in config.php, but apparently they are still being polled.
config file:
$config['poller_modules']['cisco-cef'] = 0;
Poller performance graph:
What am I missing?
Cheers,
Marcelo
Hi everyone,
config file:
What am I missing?
Cheers,
Marcelo
In the web ui look under global config
in GUI it is disabled, because of overwriting it via entry in config.php
Yeah, it makes sense, but the problem is that it was being polled.
I have removed all entries from the config file and done the necessary adjustments in the GUI. Tomorrow morning I will check how it looks.
Thanks for the support.
